Results 1 to 10 of 13
Thread: loud clunk when braking from reverse??
    croatia, zagreb
    Default loud clunk when braking from reverse??
    so, i'm experiencing something really weird. i go in reverse, drive a bit, and when i apply the brakes, i hear a fairly loud clunk from the front, it occurs ONCE when the brakes are applied, and that's it. it brakes normally, goes normally, it just gives me that clunk when i go in reverse and when i brake, i hear it *clunk* but it brakes.
    what the hell could that be??
    Jun 2005
    Cheshire, UK
    One of your brake pads is sticking on the shelf in the caliper that allow the pad to move in and out relative to the disc.
    Had the same issue with my 525. Reverse and clunk, but only the once for that day and it didn.t mater if the car was reversed first thing or last thing in the journey.
    Simple cure is to remove the pads, clean up the caliper. Apply a very small amount of copper grease to the locating lugs on the pads and re-assemble.
    I believe it was a build up of brake dust caused by cheap pads and an auto gearbox so the brakes get used more. In the end I just learnt to live with it, the e34 only did journeys in stop-start traffic so the pads were constantly creating dust.
    1997 e39 523SEi touring.
    if Omegas fix dont do it I would say its a ball joint, especially if it clunks while creeping slowly and jabbing the brakes.
    Either capiper retaining bolt is loose on one side...
    or...
    Suspension bushing gone...
    or
    Something loosy in steering.
    Feb 2007
    GreenHills East-Philippines
    Quote Originally Posted by Tiger
    or...
    or
    x2
    HID 5000k low 3000k fogs
    dynaudio seps. mc intosh amp
    Race logic TractionControl
    croatia, zagreb
    thanks for quick replies.
    well, it appears to come from the right front wheel. i already disassembled the caliper, but the brakes were fine. i also did an inspection on the bearing, well, i just tried jerking it and spining it by hand, and it all seemed quite normal.
    there is however a slight play in steering, which i think wasn't there before.
    i will have my mechanic check the ball joint...
    anyone else have any ideas, please share
    Dec 2006
    Adelaide Hills
    I have exactly the same symptom - a clunk from the front when moving in reverse and applying brakes. Nothing else. Nothing has fallen off. brakes work fine, so I'm currently applying the wait and see solution ...
    June 88 535iA, 173,000 km; Sep 00 735i 170,000 km
    Mmm... engine mount?
    Balljoint
    Jul 2004
    Vancleave, MS
    Default Ditto me too same symptom...
    just started week ago... when I go to roll in reverse out of the garage, and just genly press the brake, I get a noticeable click or something..but it ain't a clunk... like the brake caliper or soemthing aint' sitting quite right... but THATs all, drives, stops, everything perfect, no shimmy... wtfo?
    Quote Originally Posted by Podmore
  1. Loud Noises
    Last Post: 07-14-2008, 07:28 PM
  2. Clunk when changing from Drive to Reverse
    By Cephas in forum 5 Series BMW
    Last Post: 07-25-2007, 09:36 AM
  3. Loud clicking
    Last Post: 01-04-2005, 11:47 AM
  4. LOUD e34...a little help
    Last Post: 02-17-2004, 05:57 PM
