Results 1 to 3 of 3
Thread: why does my transmission "vent"
    Dec 2006
    Atlanta Georgia
    Default why does my transmission "vent"
    Recently I replaced the transmission in my 89 535i with a "good" one from my patrs car. The donor transmission had good unburnt fluid in it and had yellow crayon markings on it like it came from a junkyard or had been rebuitl. I replaced the filter and fluid as part of the install. The trans works fine EXCEPT fluid is coming out the vent ? on the top rear of the case which proceeds to drip on the exhaust and deliver smoke from under the car. I used Dextron III and bentley specified Dextron II. The fluid had dropped from nearly full to nearly add in about 500 miles. I suspect fluid foaming. Any sussgestion of a cause or fix eg. different type of fluid or additive. The transmission sat for a little over a yrear before being used.
    Albuquerque, NM
    Probably a cracked or broken vent dammit (item 17)
    I did a "Winfred" on my son's 535i this past winter & broke the tip off of the vent tube when we rolled it over at the spray wash. Now that yours is installed, it's going to be a bit of a pain to replace but you can remove the tail housing with it in the car. I don't have any pic's of the vent but if you scroll down to the bottom of this link you'll get an idea of how to get to it.
    http://www.nmia.com/~dgnrg/page_43.htm
    gale
    Dec 2006
    Atlanta Georgia
    Bump .Any other ideas? I'm going to replace the vent assembly. anything else to check when I have the rear transmission casing off?
  1. Brake Pedal "Tapping"/"Knocking" Sound - 89 535i
    Last Post: 10-16-2007, 07:12 AM
  2. TRansmission Program Error "Help Needed"!!!!!!!!!!
    By wasapppp in forum 5 Series BMW
    Last Post: 09-28-2004, 09:53 PM
  3. Replies: 2
    Last Post: 06-26-2004, 07:38 PM
  4. arghhhh coolant leak from auto transmission "strands" car...
    Last Post: 05-22-2004, 08:16 PM
