i know a few people were interested in how this was going to turn out.i moved the battery from the engine compartment to under the rear seat and used the existing 4 guage wire to bring the circuit forward,also used the existing grounding points.new battery cables pos-18 inch' neg 14 inch,850 cca battery with external vent.even with a really long starter duty cycle to initially start a bone dry injection system the cables showed no signs of heat at all and the starter turned over normally.im happy to get the battery out of the temp extreems of the engine compartment even if it's simply for piece of mind. bones
