Results 1 to 10 of 10
Thread: Need a quick answer if anyone is out there
    NW GA
    Default Need a quick answer if anyone is out there
    Just replaced the radiator in my 535i and can't seem to get the top hose to seal water tight. Is there a secret to how much to thighten, place of clamp on the neck, etc, etc, etc.
    1990 535i 5-sp., except for 16" M-Contours, cd deck, and clear corners, completely stock. 226k and running strong
    rule of thumb is err on the side of loose because of the plastic neck. Push the hose all the way on...position the clamp about 1/2" from the end of the hose. If your hose is heat aged, you will struggle a bit more with the seal. Hope you have a good worm gear clamp. Warm the car up under pressure and gradually tighten the clamp until the leak path stops. I use a 6 or 7mm socket for the clamp versus a blade screwdriver for obvious reasons...won't slip as easily and spear anything like a rubber hose :-) Use your discretion for torque....a light, deft touch. One tip is don't use a 1/4" rachet to tighten a clamp...use your 1/4 drive screwdriver with a universal if necessary and an extension with a small socket. This will help on over torquing. Do NOT over torque your radiator hose connections to plastic nipples....hmmm...I said nipples.
    George
    freezin ass cold WI formerly freezin ass cold MN
    Yeah, don't over torgue the nipples. They're sensative.
    95 540 six speed, Rondell 58 wheels, nothin else special
    79 911 SC - pea soup green
    is that over tongue or torque? Yes they are...in a wonderful way.
    George
    Default Did you make sure that there wasn't a bunch of deposits on the inside of the
    hose before you put it on? Sometimes you have to clean out deposits from where it had been leaking in the past and then use a little hylomar on the hose to radiator connection..
    Quote Originally Posted by Mitch90535im
    Default Had this same problem in my m30 a while back...
    and wound up placing the hose clamp on top of the end of the nipple with the corrugation. It sealed better but still dripped one drop at a time. The crud and deposits didn't help with the sealing. Finally collapsed the nipple. Bought a new expansion tank and it was nice to see a metal sleeve under the plastic nipple for re-enforcement. Still a lame design.
    NW GA
    I really appreciate all the help guys.
    My final solution was to shorten the hose about 1.5" to get past the old "threading" left on the inside from being clamped for so long to the old radiator neck/nipple. Luckly the wifey was on hand as is often the case when I'm playing shade tree mechanic to pry the wrench from my trembling, sweaty hands (she has this nack for sensing when I'm about to be a "man" and break something) and she was able to tourqe it just tight enough to stop the drip without destroying the new radiator.
    I owe her a lot with regards to helping with the e34. She did the re-solder on the LKM, installed my front clear-corners, and promised tonight she was next going to tackle that pesky intermittent "tail light" problem. I have no doubt it will soon too be a thing of the past. The only time I ever doubt her is when I see her break out the duct tape.
    Again, thanks for the help and kudos to Patrick at BMA for standing behind his service and getting me the correct radiator overnight after shipping me a 525i radiator last week.
    Time now for a beer...
    Boy! Does she have a sister?
    my mom is a licenced gereral contractor/designer for almost the last 15 years, before that for about a year she was a small aircraft mechanic
    Default this is what i found when I was thinkin bout my radiator
    someone other than I know
    then I remembered I was supposed to be married...damn, hope she dont have this page book marked
  1. Replies: 27
    Last Post: 02-08-2007, 12:57 PM
  2. I will not answer any more.......
    Last Post: 08-30-2006, 07:28 AM
  3. No one knows the answer.
    By Island530i in forum 5 Series BMW
    Last Post: 02-25-2006, 04:44 AM
  4. Replies: 22
    Last Post: 08-11-2005, 11:25 PM
  5. Replies: 9
    Last Post: 07-18-2005, 03:53 PM
