the bushes are stronger, not the arm itself and the m5 bush is the strongest one available. It would be easy to change the lower arms at the same time as the upper arms
My 540 has developed the dreaded 50 mph vibe so i'm replacing the upper arms. I'm also doing the pads & discs at the same time, but is it worth my while doing the lower arms as well?
I hear the upper arms are a very common problem and cause of this vibration, not heard much about the lower arms.
I've also heard that you can fit the arms from a 750 as theyre stronger? Any truth in this, and anything to be aware of if doing this?
Cheers
Thanks
I'm in the UK, and it seems, I can get the arms without the bushes fitted. This being so, it also seems, I need to get the bushes 'pressed' into the arms by machine. I'm sure I can locate a workshop that could do this, but if the bushes are fitable, are they not also removeable? Do I really need to replace the arms, or can I replace the bushes on their own?
Ta
like kriss said go with the M5 bushings, even I havent tore them up yet.
Thanks
Just ordered the entire powerflex kit so guess i'll be busy doing the rears too. Funny how needs turn into musts cos I also ordered all new discs n pads all round too
I've a good excuse tho, the football season starts again in the UK in 10 days so I don't have long to get all the bits fitted
Cheers
Go Spurs !Originally Posted by choccibicci
"I'm not the village idiot.
