Voltage looks ok. I believe Test 6 is remaining fuel in liters, not charging amps.
http://bmwe32.masscom.net/johan/obc_...c_secrets.html
Paul Shovestul
Originally Posted by
BennyM
OBC test #9 reads somewhere betweeen 13 and 13.9 volts while the engine is running. This seems a tad low, but still within acceptable limits as far as I can tell.
Here's the weird thing:
OBC test #6 reads only 9 amps while running. It peaked at 11 amps at one point, but generally stayed right around 9 no matter what accessories were turned on. What's the deal here? With low amperage like this, I'd think the car wouldn't even run, yet everything seems to work fine right now.
Any thoughts on those readings? Is my OBC full of it?
