Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: OT: Car lift? How about Car tilter.
    Central NJ - USA
    heeh
    The rocker assemblies are mad from heavy angle iron
    from eastwood website
    Jun 2007
    Cheshire CT
    Quote Originally Posted by Macv
    Wtf. I've never heard of them, doesn't look like I'd use them either.
    http://www.eastwoodco.com/jump.jsp?i...rID=142&KICKER
    Input?
    Let me start off by saying this: You're all a bunch of skirts.
    Would I buy that? Probably not, because I'd spend my money on a real lift. Would I use on at a shop that had it? Absolutely. it looks like it would make it a piece of cake to change out FWD trannies and engines. Changing a clutch? putting a tranny in? It's a lot easier trying to make it line up when it's on it's face than when you're trying to make the face line up while the car's horizontal.
    I imagine the majority of you have worked on a car using ramps, or jacks and stands. This thing has to be safer than ALL of them. Making fun of angle iron? Why? sure, there's weak iron, but then again, all the lifts in my shop here only have two posts, would all of you be afraid to get under a car because you're skittish about the lift tilting over?
    Grow a pair, huh?
    Dec 2006
    how exactly are you going to hold the heavy tranny or engine in place horizontally while you line it up?
    baton rouge, loserana
    i turn cars on their side to pull **** when we crush and it's something of a pain in the ass to pull big stuff, nothing is designed to lift things at that angle, fluid is dripping from the diff and tranny vents and any other place that's not designed to operate at a 90* angle, i pull parts off cars when they are hanging from the forks of this
    that thing looks like a **** load of square tubing and it's around 2/3 the price of a real lift (actually our one rotary we got used for $900 and $300-400 to install)
    Quote Originally Posted by Bin_jammin
    Grow a pair, huh?
    These things are intended for body work. Far less useful for servicing.
    Indiana
    I wouldn't want bodywork done to my car at an angle. Think of the damage it would cause.
    Oldham, England
    Grow a pair, huh?
    I changed FWD engines and/or trannies rather more than I would have liked. I found they are also quite heavy and subject to the same laws of gravity as 'normal' engines/trannies. I'm not quite clear how you support a transverse engine when you remove the gearbox if the car is up at an angle. But maybe as you suggest I'm talking bollocks
    Feb 2007
    New Forest, ,UK,
    They are for bodywork only,as they bolt onto the hubs not much point in working on them,also oil tends to spill out of dipstick etc,seen an XJ12 on one and it supported it fine.
    Jun 2007
    Cheshire CT
    Quote Originally Posted by whiskychaser
    When you're installing a FWD tranny, and you're trying to line the bellhousing up, and you're manhandling it to get it to sit on its dowels, you're also supporting the weight of it, either by using a tranny jack, or your hands, or something. If you could tilt the car so the bellhousing is face down, you won't have to support the weight at the same time, and it should just plop right onto its dowels.
    Sounds a lot easier to me.
  10. #20
    Dec 2006
    how would you get the tranny up to the right height and then move it over laterally?
  1. OT: DIY Gearbox lift
    Last Post: 07-16-2008, 01:59 PM
  2. E34 Face lift , how much ??
    By vadim_braia in forum 5 Series BMW
    Last Post: 03-23-2007, 06:54 PM
  3. Lift carpet by glovebox ?
    By bagpuss in forum 5 Series BMW
    Last Post: 09-17-2006, 05:11 PM
  4. Time to buy a lift. What about harborfreight?
    By Bruno in forum 5 Series BMW
    Last Post: 07-07-2004, 10:51 PM
  5. E34 gas lift glove box
    By jplacson in forum 5 Series BMW
    Last Post: 03-06-2004, 08:54 PM
