I know... I hate it when people put chrome all over the place with no taste whatsoever...Originally Posted by repenttokyo
AMEN !
AC Schnitzer | S-5 | Stainless exhaust | Bodykit | wing| 3pc. wheels | badges | springs | mirrors | steerwheel |
Schwarz on Blk
PMSL!Originally Posted by wjbell
Cheers,
Shaun M
Originally Posted by tgrandahl
I always think outside the box. If you prefer one arm over two because to your eye it looks better, do it. If you think it will make your car faster (and you can prove that it will) do it. If you're doing it because you want to protect the paint on your hood, fix your car. There's a reason it's hitting, something is either mis-adjusted or worn.
If you still feel the need to modify your car and think outside the box, add a wiper part stop. A lot of cars have them, they're little black (usually) plastic things that the wipers park against. Basically it solves the problems you have. If you really want to further mod your car, find one that has a squirter nozzle built in, or see if you can find one that has a heated squirter, as it will keep the ice from forming on your wipers.
Come to think of it....
How about the old Jags with 3 arms?
Is there a 3 arm conversion?
...j/k btw
Had to look that one up... !Originally Posted by E34-520iSE
Ok, so im looking at the real oem blow up and it sounds like your referring to "06-RUBBER BOOT-3-61611378537-$4.30" Is this the part you replaced? It will be great to be able to order this before i pull the assembly and such.Originally Posted by bmwrp8
nope its the damper ring..no.16 and 24...but before you order check it first ...the damper might just be misaligned like my friends....Originally Posted by tgrandahl
HID 5000k low 3000k fogs
dynaudio seps. mc intosh amp
Race logic TractionControl
Oh wow waitup so you dont even have to pull the assembly to replace them? I will take a good look when the sun comes up. ThanksOriginally Posted by bmwrp8
yepOriginally Posted by tgrandahl
