Thread: car dies, need help
    Jun 2006
    southaven miss.
    Default car dies, need help
    hi, 90 525i automatic, several times in last couple of days when my daughter was driveng my car, it has died completely all of a sudden, no electrical power, it starts right up again, happned when backing up and while driving straight, i drove it all around and couldnt duplicate it, i dont see anything obvious, is there anything that i should check?, thanks
    Nov 2005
    Have a look at the battery under the rear seat, see if the cable to that bat is loose any. (I'd be suprised, but you never know.)
    Jun 2006
    southaven miss.
    my battery is under the hood, that was the first thing i looked at, could a bad alternater cause it?, but then it starts right back up, it has me baffled.
    Nov 2005
    Unfortunately, I'm no electrical systems specialist. My other uneducated guess from other posts would be a relay. We'll have to wait for a more experienced reply.
    But someone here had a different problem where the alt fan would come on with a couple of faint dash lights coming on when the engine was off, key out, and it turned out to be a relay problem.
    Mind you, with a Toyota I used to own, I blew the alternator, and so all the electrical had gone. I jumped started it a couple of times (push, 2nd gear... that routine) and took it to a garage.
    Perhaps a look at the Bentley manual might help. You can download it. Somewhere within the threads here is a link to a 60MB file in pdf.
    Maryland, Virginia, D.C.
    Nov 2005
    Ah, here we go, fusible link. I do like to type for no good reasons sometimes.
  1. M30 dies when stopping periodically
    By Asamaan in forum 5 Series BMW
    Last Post: 05-07-2010, 01:42 PM
  2. m50 starts but dies
    By 89_525i_PhoenixAZ in forum 5 Series BMW
    Last Post: 06-27-2008, 07:27 PM
  3. engine dies!
    Last Post: 11-21-2007, 05:03 AM
  4. 89 525 dies when put in gear
    By barry 90 525i in forum 5 Series BMW
    Last Post: 10-27-2007, 09:21 AM
  5. 540 starts, then dies
    By onewhippedpuppy in forum 5 Series BMW
    Last Post: 11-14-2005, 05:48 PM
