more likely just corrosion in the connector
I have a 1990 525i and the low beam light stoped working on the right side. I checked the voltage and it is only around 9 volts not 12 volts like it should be. Do I have to get a new light control module or is there a relay causing this?
Which connector? I am getting the 9 volts at the builb and the fuse.Originally Posted by Ross
That changes things. Fuses 10 & 11 are fed from the LKM The light control module is a common failure on these cars and lots is covered here on it.
EDIT ///Sniper 535 is selling an LKM on the cheap.
try to solder the LKM if that doesn't work just buy a 2nd hand one...its cheapOriginally Posted by franks
HID 5000k low 3000k fogs
dynaudio seps. mc intosh amp
Race logic TractionControl
