Results 1 to 10 of 16
Thread: Rear pad question - In the middle of it now
    Sep 2006
    Coarsegold CA
    Default Rear pad question - In the middle of it now
    Hi All...
    Been chasing a rattle. Pulled left rear and found that the pads seem to have some slop to them. No rear break BMW experience, but never saw anything like this before. I have always seen pads fit snug. It seems to have slop on the carrier and the caliper.
    Don
    1994 530it 147,000
    1983 300SD 278,000 (running soybean oil)
    1980 300TD 135,000 (running soybean oil)
    Feb 2007
    Lebanon,TN
    If it is the same problem my e36 had, the caliper has a "spring" that keeps it from rattling and it was missing. I'll look for a pic.
    Feb 2007
    Lebanon,TN
    # 7 in the diagram.
    Sep 2006
    Coarsegold CA
    Herb,
    I have the spring... but the pad can rock up and down (direction of wheel rotation) almost and 1/8" As though the slot on the pad is to large.
    Don
    1994 530it 147,000
    Feb 2007
    Lebanon,TN
    Don, I am at a loss, unless the supplier gave you the wrong pads?
    Sep 2006
    Coarsegold CA
    I was not in the process of changing pads, but tracking down a couple of rattles in the rear.
    From what I can see and again I have no experience with BMW brakes...
    The pads to fit properly would require the metal plate to be 2 different sizes to accommodate the difference between the caliper and carrier.
    I will call a BMW parts house tomorrow and find out if all the pads come one size or if someone makes an inner and and outer.
    Don
    1994 530it 147,000
    Inner and outer are the same size.
    Sep 2006
    Coarsegold CA
    Ross your right....
    I am going to do the rear brakes (Brembo rotors and Akebono Euro pads) and hope the the cross spring that inserts into the puck, along with the new anti-rattle spring solves the problem. If not ...there is always duck tape or silicone. (kidding)
    1994 530it 147,000
    Reading, UK
    Quote Originally Posted by BIGRED
    Ross your right....
    While you're at it, grease the brakes as well to muffle the squeaking
    That's funny. Sadly I once witnessed a "mechanic" at a dept. store auto shop put anti sqeal compound on the friction surface of brake pads. Didn't stick around for the outcome.
  1. Drifting in the middle of the road
    Last Post: 11-26-2006, 11:01 PM
  2. 91 525i muffler middle or rear?
    By csirisky in forum 5 Series BMW
    Last Post: 05-16-2006, 11:56 PM
  3. Car died in middle of nowhere in rain storm
    By xtmsports in forum 5 Series BMW
    Last Post: 03-29-2005, 10:51 AM
  4. Replies: 2
    Last Post: 06-08-2004, 12:13 PM
  5. PLZ HELP Weird noise in middle of car!!!
    By Bobby in forum 5 Series BMW
    Last Post: 04-26-2004, 12:01 PM
