Originally Posted by
mikeythekidd
My a/c stopped blowing cold air so I took it to a local indy to get it tested for leaks. They said the condenser was leaking so bad they couldn't fill it. They gave me an estimate of over $800 to replace it! I ordered a condenser, drier, hose and o-rings from BMA. I have done a search and found the info. on this forum somewhat incomplete. Also, the Bently I have skips over the condenser. Any tips, links, write-ups would be greatly appreciated.
Not that terrible a job - you did good ordering through BMA, my first was not through BMA and I got stuck (too thick, other dimensions okay). I also had a broken aux fan (replaced it as well), you might want to check that. I did pull my radiator to get this swapped out if I remember correctly (and pulled the front bumper to get at aux fan), not a big deal. My condenser was leaking at every joint, it was real bad.
I used a cheapo vacuum pump that runs from a air compressor - I would suggest using a real motor driven vacuum pump if you can get one (borrow). I also replaced the expansion valve - don't recommend that unless you are into pain. I also put in a new compresser and rec/drier which you will likely want to put in as well. All in all, I spent about 900$ including tools (gauges, pump, etc) and everything is now new (I did not swap out evap or the lines).
Scott
edit - is your system R12 or R134?
07 525i 22K, 07 328xi (41K)
