Results 1 to 5 of 5
Thread: Cruise control problems
    Mar 2004
    Brisbane, Australia
    Default Cruise control problems
    I was driving down the highway last night and hit the cruise. after i had selected the right speed it slowly started climbing up and up. hit the brakes, kept climbing back up. i couldn't cancel it either on the stalk, it would only increase the car's speed.
    managed to stop the car even though it was like i had the throttle planted. turned the car off and had a look under the hood thinking that the cable had jammed or something but it was totally slack. i started the car again (in neutral) and straight away the revs went shooting towards the redline. turned the car off and again, the cable was slack with the throttle closed completely. i ended up unplugging the cruise control and that allowed me to drive on safely.
    is it a case of my cruise control being stuffed?
    thanks for any help
    Quote Originally Posted by Rory535i
    thanks for any help
    Had this when I first got mine. CC wouldn't cancel. It turned out to be the brake light switch, it has a seperate circuit for cancelling CC. Get a new one. If you force the car to stop under brakes onse the torque converter has locked in 3rd or 4th it will damage the tranny.
    Interesting though, you say cancel on the stalk didn't work.... I"m not sure that was the same for me... could have been tho. I also had to emergency stop. Nick
    Nov 2006
    Germany
    Quote Originally Posted by genphreak
    Is this a vacuum controlled system? If so, you could have a sticky vacuum control valve...
    Brian
    Houston, TX
    Nope - it's entirely electric.
    If neither the stalk or brake switch cancel cruise, could be the control unit, but that's only a guess.
    Great Britain
    I posted (with pictures) some stuff a few months ago about how to repair the cruise control actuator - might help.
  1. Cruise Control E34
    By TWISM in forum 5 Series BMW
    Last Post: 04-05-2006, 01:00 PM
  2. Cruise Control Q........
    By Mewsy in forum 5 Series BMW
    Last Post: 01-22-2006, 01:58 PM
  3. cruise control problems..........
    Last Post: 12-26-2004, 11:26 PM
  4. Cruise control
    By Gerrit in forum 5 Series BMW
    Last Post: 08-19-2004, 03:47 PM
