Results 1 to 10 of 17
Thread: Eibach and no drop?
    Feb 2007
    La Habra, CA
    Default Eibach and no drop?
    Finally got the front end buttoned up with all new parts including eibach's. Drove it around the block a few times, checked all the bolts, drove around some more and then parked it to check out how it looks... Exactly the same as it did before. The front is still way too high and the rear sits down nicely.
    Any suggestions would be appreciated.
    At least it handles better...
    Eric Claussen
    La Habra, CA
    1993 525i 5 speed
    Feb 2007
    GreenHills East-Philippines
    Quote Originally Posted by etcetera
    what kind of eibachs did you get?? My friend bought an eibach in his z3 same ride height but stiffer ride just the way he likes it
    HID 5000k low 3000k fogs
    dynaudio seps. mc intosh amp
    Race logic TractionControl
    Victoria, Australia
    Give them a bit of time and you will find they settle down an extra cm or so...
    Old car: 95 525i, OB/Silver, Eibachs, Style 66, Missed dearly!!
    VIN Decoder | Online ETK
    | E34 Bible
    Melbourne, Australia
    Are you certain you haven't wound up with springs for a V8 E34?
    I've had Eibachs mis-packaged on several occasions. I remember specifically, Golf springs inside Jetta boxes or two seperate occasions just off the top of my head. So I agree with Pundit, check the actual part number painted on the spring...I know, I know, it's not easy chore since they're mounted.....but that's really the only option to verify the correct part for the application.
    1995 540iM Alpine White/ Lt Silver Grey 84k
    1992 535iM Black/Lt Silver Grey 132k
    1990 535iM Glacier Blue/Blue 206k
    Feb 2007
    La Habra, CA
    The part # is correct. Don't recall exactly what it is but it corresponds with a 1.3" drop in front and 1 in rear. I'll be driving it today, hopefully it'll settle down a bit more, like an inch more.
    Eric Claussen
    La Habra, CA
    1993 525i 5 speed
    Can you post part numbers please?
    Thanks.
    BMW, THE ULTIMATE FLYING MACHINE
    SPEED AND POWER IS NOTHING WITHOUT CONTROL,
    THANK THE GERMANS, BMW HAS ALL 3
    Are you reading the number from the actual spring, or the box? If it's the proper spring, you have no chioce but to wait it out and hope they settle. Good luck !!!
    Hmm, my eibachs made quite a difference. Same engine (M50) as well.
    Out of interest, what shocks did you pair them with and did you install 3mm spring pads? I went with new, stock boges and 3mm pads and haven't had any issues, complaints, bottoming out.
    Hope they settle for you,
    Dave
    Maybe you had a M-Tech spring when you switched to Eibach.
  1. Drop it like its hot
    By ArnZ! in forum 5 Series BMW
    Last Post: 09-24-2009, 10:04 PM
  2. big drop off in mpg
    Last Post: 05-05-2006, 08:02 AM
  3. Volt drop vs fuel pressure drop/stumble
    Last Post: 04-24-2006, 07:06 AM
  4. So how much drop?
    By Island530i in forum 5 Series BMW
    Last Post: 02-09-2006, 03:05 PM
  5. RPM drop...
    By TETSUO in forum 5 Series BMW
    Last Post: 04-05-2004, 11:37 AM
