Friend
BMW START AND STOP PLZ SEE BWLOW AFTER USING CAR DIGNOTICS
I WANT TO MAKE SURE THAT IS REASON FOR NOT START
AND IS DISEL
THX
Friend
AND IS DISEL
THX
if your car is diesel maybe you have a water in the fuel filter...When you say "CAR OFF IMMEDIATELY" do you mean there's no power inside?or the just the engine itself dies?do you have any warning lights that is illuminated or in the Check Control display?anymore info would help!Originally Posted by salih
HID 5000k low 3000k fogs
dynaudio seps. mc intosh amp
Race logic TractionControl
Hi
friend I want to make sure if that car is not have secuirty key problem
some peoples told me when is key secuirty problem car never start
is that true i want to make that sure second as i said in title
after 15 second car off and i have chnage all filter and dump
in diagnotics i have this problem
code 1195 rail pressure sensor
code 3505 glow system
code 1190 rail pressure regulatoin
code 0100 air mass flow sensor
thxi
if you have security problems or immobilizer problems the car would not crank.In your case the car cranks and starts so its not a immobilizer issue.As for your problem about your car only starting around 15seconds then dies...you pulled out the codes...you answered your question on why your car dies after 15secondsOriginally Posted by salih
