Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Tyre pressure
    Feb 2007
    Its worth a try, asc is generally under worked anyway!
    Feb 2007
    GreenHills East-Philippines
    Quote Originally Posted by leicesterboy15
    true true
    HID 5000k low 3000k fogs
    dynaudio seps. mc intosh amp
    Race logic TractionControl
    El Paso TX
    Quote Originally Posted by Ferret
    I tried a 35 front 38 rear combo once, and wont ever do it again - It caught me out twice in one day, the rear end of the car sliding around a roundabout.
    I now run it the other way around with 38 up front and 35 at the back. Too much PSI at the back causes the car to yeah, handle well, but when the grip starts to go you've had it. Hard rears on a RWD car is asking for trouble in my opinion...
    that's because you have more torque down low than us petrol guys.
    I run about 35 front 40 rear also
    I bet your tires were bald too... or somewhere near that. Have you checked your sway bar links too? We ran as high as 39 front and 43 in rear and never experienced what you have...
    Now as I was typing recalled once that our car never had the rear shocks changed and everytime my dad went around a good turn, his rear end always went out of control... Once we changed the rear shocks, no more problem. So I think this is why it happened on you.
    Windy City
    You should always use less pressure up front than the rear (like BMW recommends) for front engine cars. If not, it will create more understeer… Something that all 5 series suffers… I have 35 psi front and 38-39 psi rear. But all this is subjective and each to their own… Whatever fits your driving style...
    Quote Originally Posted by bsell
    I run 40 psi front and 35 psi rear with 235/45/18 tires. I found that running the rears hard (like BMW recommends) is too much for me most of the time. I drive by myself 95% of the time, thus the rear end is very light compared to BMW's thinking.
    When the snows are mounted (stock sizes) I keep the same five pound difference, biased to the front for the same reasons. The car handles better with similar tire roll rates.
    Brian
    RICK
    BMW 1995 525i (Alpine White)
    Dec 2006
    Adelaide Hills
    Hmmm - my thinking is that even with a well-balanced car like the E34, there's a bit more weight in the front than the back, so apart from other considerations such as ride quality, to keep the size of the tyre contact patch pretty even between front & rears, it's necessary to have the front inflated a bit more than the rears. My experience is that LOW pressure in the fronts will cause more understeer than high pressure due to the sidewall flex which allows the tyre to roll more on the rim, thus lifting up the inside edge of the tread on cornering and reducing the contact patch, leading to reduced grip - just another 2 cents worth from me ....
    June 88 535iA, 173,000 km; Sep 00 735i 170,000 km
    Windy City
    I'm not talking about low tire pressure that will create the complete roll here... But understandable where you're coming from... That's what I used to think but it is opposite... You can do a search and see for yourself. Tighter rear will bring the tail around...
    Quote Originally Posted by Podmore
    RICK
  1. Tyre pressures
    By stx133 in forum 5 Series BMW
    Last Post: 01-23-2009, 03:26 AM
  2. Best tyre size???
    By Rupster in forum 5 Series BMW
    Last Post: 07-07-2008, 08:35 AM
  3. Tyre Pressure 225/55/R16
    By karl1171 in forum 5 Series BMW
    Last Post: 10-31-2007, 10:59 AM
  4. Tyre pressure help
    By jga540iAT in forum 5 Series BMW
    Last Post: 12-17-2005, 09:59 PM
  5. Tyre Psi
    By SIXPACKDREAMER in forum 5 Series BMW
    Last Post: 05-04-2004, 10:14 AM
