Can't answer 1 but the starter motor is not fused.
folks, 2 questions:
1. what is the max current drain of the starter motor during cranking?
2. is there a fuse that protects the starter motor circuit - where is it and what is the ampere rating?
'01 540it, 6/01
'03 325i 5 speed, 9/02
'10 535ix. 9/09
'10 mini 6 speed
'15 mini countryman 6 speed
Several hundred amps? More if it's cold (and the engine is hard to crank)?
At cold on such a big engine, while the starter motor is in stall and voltage applied, it can draw upto 450 ish amps instantaneously.
It IS CATEGORICALLY NOT feasible to use that trunk cable.
1.8kW continuous = 150Amps...Originally Posted by ryan roopnarine
However that will spike massively while the motor's stalled.
ferrett,i just moved my battery from the engine compartment to under the rear seat.im hearing all kinds of cautions about the 4 guage wire that is allready there being to small to carry the load.the factory used a 2 0t positive cable in the engine compartment and then used a 4 ot to ground the battery to chassis.the circuit cant handle any load greater than the 4 ot ability to ground the circuit.is this correct?.bones
could you post a pix of the battery under the rear seat and what it looks like now on the engine bay?? I'm thinking of doing this also if its not that hard.Originally Posted by bones
HID 5000k low 3000k fogs
dynaudio seps. mc intosh amp
Race logic TractionControl
