Results 1 to 7 of 7
Thread: found the leak in my AC system
    Default found the leak in my AC system
    Just for info:
    the pressure sensor attached to the dryer was the culprit. It leaked between the threaded part and the electric part, where they are crimped together.
    Here some pics of the 'jelly droppings'.
    Also changed from R12 to R134a on this occassion
    http://www.bimmerboard.com/forums/posts/376694
    Roswell New Mexico
    when you changed the refigerants did you have to change out the dryer???
    Sep 2005
    Dallas, TX
    I recently completely refurbished my AC system. I found 3 leaks -
    Low pressure side schrader valve
    expansion bock
    Compressor shaft seal
    I wound up getting a remanned compressor, new expansion block, new valves, new o-rings, and a new drier. Completely flushed the system with mineral spirits, and installed ester oil. Vacuumed the system for a solid hour, then installed R134.
    In case anyone is worried about the efficiency of R134 in an E34 designed for R12, I am currently seeing temps as low as 35F in 90F ambient temps.
    Quote Originally Posted by Dr. evil
    Yes, I did that. Different oil is used.
    "The older mineral oil used in combination with an R12 system will not mix with R134a coolant and will get into the dryer blocking the system. This can cause servere damage to the compressor. So be sure to get as much of the old oil out as posible. You can unbolt the compressor and pour out the old oil or have a shop flush the system with R12 to remove the old oil. "
    That is an excerpt from the instructions from Johan here
    http://bmwe32.masscom.net/johan/airc...con_R134a.html
    A new dryer you can get for less than 50$ for example from www.autohausaz.com
    The compressor in my car was changed in 1994 once, so no problem with incombatibility to R134a. See details in the link.
    Roswell New Mexico
    thax shogun
    YOUR THE BEST!!
    <EPA certified and your dead nuts on about the oils.
    Sep 2005
    Dallas, TX
    I used something similar to this to flush out all the old oil:
    http://www.ntxtools.com/network-tool...-Retrofit.html
    Fill 2/3 with mineral spirits, then charge with compressed air. Once you finally get clear fluid, you can blow clean with compressed air.
  1. found my coolant leak
    By 525i winter driver in forum 5 Series BMW
    Last Post: 05-13-2008, 07:42 PM
  2. FOUND MY LEAK!!! pls advise....
    Last Post: 07-15-2005, 04:18 PM
  3. I think I found my oil leak
    By granit_silber in forum 5 Series BMW
    Last Post: 02-04-2005, 07:18 PM
  4. My First 535i, Found Stop Leak in Radiator.
    By rot535i in forum 5 Series BMW
    Last Post: 01-10-2005, 08:47 PM
  5. Replies: 3
    Last Post: 07-27-2004, 05:57 PM
