Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 31
Thread: E34: Battery transfer (front to rear seat)
    Feb 2005
    Penang, Malaysia
    moots, there is already an existing heavy gauge wire - no (3) on my diagram - connecting the fuse A and fuse B - albeit it is not as thick vs the ones to the starter motor from the front battery terminal.
    Quote Originally Posted by moots
    yes perhaps the batt will last longer located away from the engine heat but i really am not keen to route a thick gauge wire from the rear seat....tell us how it goes shud u decide to proceed.....me Malaysian too....he he
    Feb 2005
    Penang, Malaysia
    ferret, here's the existing front engine +ve connections and the front main fuse:
    Quote Originally Posted by Ferret
    Kttroh, snap us a photo of the +ve batt terminal and the leads coming out of it plus where they anchor... I was sure my 525i only had small leads coming off the batt to the fuse point.
    Reading, UK
    Quote Originally Posted by ktteoh
    ferret, ok. i will snap that when i get home. meanwhile i would still like to know if the wire no (3) - connecting fuse A to fuse B - can cope with the current load demand of the starter motor.
    it looks like a heavy gauge wire but the one (at the front battery) to the starter motor is "thicker".
    thoughts?
    Hurr, it'd probably kick the engine over happily from a short burst. But, more than a few seconds cranking would cause that wire to heat up badly, and it runs under carpet. I'd hit a scrap yard and rip out the battery wire off something with an underseat battery rather than risk pushing that...
    I had a look at my diesel one while I was just out doing the rear brakes, and it's around the 3/4" thick mark. (Though, diesels do take a hell of a lot of current to start and its got a massive battery.)
    Yep, that little wire won't handle the starter load. 4 gauge is what you need.
    Feb 2005
    Penang, Malaysia
    what is a 4 gauge - would a battery cable that handles 60A do? or 100A?
    Sep 2006
    Coarsegold CA
    Seems like a lot of work at a fair cost to accomplish something that a month later will be forgotten (of course that is said without having an understanding of what you are experiencing).
    Curious as to why this seems to be an important modification? I noted a mention of hot temperatures. Is it killing batteries that warranty won't cover or at such a rate that its a pain?
    For myself, I would have preferred to have the battery located under the hood. Not all that keen on having something with acid sitting under my kids. I know of a couple of battery explosions, but trust that BMW knows whats best.
    Regards
    Don
    1994 530it 147,000
    1983 300SD 278,000 (running soybean oil)
    1980 300TD 135,000 (running soybean oil)
    Reading, UK
    Quote Originally Posted by BIGRED
    Regards
    Don
    Hmm, as well I've just remembered that the battery should have a heat shield up one side of it as standard fit on an M50 bay...?
    Yours gone missing somewhere ktteoh?
    Feb 2005
    Penang, Malaysia
    ferret, the ones in malaysian market somehow doesn't come with the head shield (for the exhaust side) - i asked before. anyway can send me a picture of what the heat shield looks like?
    for the wire (3), i notice that fuse B is rated at 80A - would that indicate that wire (3) is sufficient for 80A - if so would 80A be sufficient for all electrical load during starting.
    Feb 2005
    Penang, Malaysia
    shogun, what are items 7, 12 & 14 - it is not in the description? i think i'm missing those items in my current setup.
  1. Replies: 5
    Last Post: 06-28-2007, 07:32 PM
  2. E34 battery move (engine to rear seat)
    By ktteoh in forum 5 Series BMW
    Last Post: 03-15-2007, 02:27 AM
  3. Under Seat Battery Kit????
    By McWatters in forum 5 Series BMW
    Last Post: 01-12-2006, 12:57 PM
  4. removing battery under electric rear seat
    Last Post: 07-26-2005, 11:24 PM
  5. Battery, Back Seat, Help!
    By all2kool in forum 5 Series BMW
    Last Post: 09-22-2004, 10:29 PM
