Results 1 to 10 of 10
Thread: Stomp test worked (finally!) - how do I clear codes?
    Dec 2005
    Nashville, TN
    Default Stomp test worked (finally!) - how do I clear codes?
    Bentley / website say to wait for a 1000 code, then hold down the accelerator for 10 seconds. I never get that; it just keeps cycling through 1221 (O2 sensor). I'd like to clear the codes and see if it throws again. Advice?
    1995 525iM - 131k - Alternator play, broken s-belt
    1995 525iA - 147k - Tensioner weirdness, broken s-belt
    2001 Intgra GS-R - 130k - spun bearing
    2002 Honda Odyssey - 80k - fragged transmission
    PA
    Disconnect battery, drive. Hope you fixed your ****
    Dec 2005
    Nashville, TN
    Hmmm. Proposal on how to start the car once the battery is disconnected?
    I kid, I kid. Will disconnecting the battery and letting it sit clear the codes (as well as all my other useful stuff like radio presets, clock, etc?)
    Victoria, Australia
    What did you have to do to get your stomp-test to work? I'm having troubles with my 95 525i.
    Thanks
    Old car: 95 525i, OB/Silver, Eibachs, Style 66, Missed dearly!!
    VIN Decoder | Online ETK
    | E34 Bible
    Dec 2005
    Nashville, TN
    Start stomping instantly, and rapid-fire - picture it like this:
    Step 1 - Insert key
    Step 2 - Turn key to "on" positionSTOMPSTOMPSTOMPSTOMPSTOMP.
    Works a treat.
    you could just disconnect the ECU for a few minutes and you wont lose the radio code.
    Dec 2005
    Nashville, TN
    Default You da man. I'll try that tonight. Thanks! [nt]
    <nt>
    Dec 2005
    Nashville, TN
    So, uh, I figured that I'd knock this out with my trusty Bentley and can't freaking find it. Bleh. So, uh, how does one disconnect the ol' ECU? Thanks in advance.
    pop the hood, remove the ECU cover on the left hand side by the firewall....disconnect the ecy connector. I dont know which one is the ECU on the 525 or 535 but you could pop them all off for about 10-30 seconds and pop them on with no adverse results. Might be a good thing to reset all of them anyways.
    Quote Originally Posted by ProZak
    Dec 2005
    Nashville, TN
    Fabulous, I'll give it a shot and let you know. Thanks!!!
  1. BMW stomp test blink codes fault codes
    Last Post: 11-12-2009, 10:53 AM
  2. Fault codes w/o stomp test???
    By billkirk in forum 5 Series BMW
    Last Post: 10-30-2007, 08:42 AM
  3. stomp test codes for all DME's
    Last Post: 04-23-2005, 12:59 PM
  4. stomp test codes???
    By johnnyturbo2002 in forum 5 Series BMW
    Last Post: 11-22-2004, 09:19 PM
  5. Stomp test for 525i codes
    By bestlawnintown in forum 5 Series BMW
    Last Post: 08-18-2004, 06:21 PM
