530s are a extra special pain in the ass to check the fluid, in the bottom of the pan theres a hole up into the pan with a big plug in the top of it, get the tranny warmed up pull the plug and squirt fluid up and into the pan till it runs out, dextron III will work ok, you will need some sort of pump with a short piece of tube to stick up into the tranny's *******, you gotta sorta squirt at a angle to get it in the pan or it will just fall back down out of the gaping *******
