Results 1 to 10 of 14
Thread: 530 auto slipping... "just a fluid flush"?
    TC535i Guest
    Default 530 auto slipping... "just a fluid flush"?
    Looking at buying a 530 wagon, and the transmission is slipping. Is this ever just a service issue, or is it a downward slope from here?
    If it doesn't work out, I know a 4 liter and 6 speed that really wouldn't mind having a touring host...
    TC535i Guest
    Oh, and do the autos have a tranny dipstick to check level, color, etc?
    Marietta, GA
    Quote Originally Posted by TC535i
    Nope, no dipstick on the auto tranny.
    It is possible he got a leak and didn't top it out that the fluid level is low.
    Or he did the work himself but didn't know he is supposed to have car running while topping off the fluid.
    Or... the tranny simply got a problem.
    TC535i Guest
    Quote Originally Posted by Tiger
    I think this is kinda a "second car" sorta deal... might be low, he mentioned that. Of course, he is trying to sell a car.
    Maryland, Virginia, D.C.
    There is no always, but often it's a fluid issue. Kinda need to know the mileage and if he ever changed the transmission/differential fluid. If he doesn't know and it's over 80K, there's your answer. I would use it to negotiate a cheaper price, and replace the fluid and done and done.
    TC535i Guest
    Quote Originally Posted by ThoreauHD
    He doesn't know, it's over 80k, and it's been negotiated (2500). I just want to know if that's a solution, or if "the damage is done"
    I would say if the car is under 120,000 miles, it is very unlikely the car has a transmission issue that required a rebuild.
    $2500? That is cheap enough... what are you waiting for?
    TC535i Guest
    The weekend?
    baton rouge, loserana
    530s are a extra special pain in the ass to check the fluid, in the bottom of the pan theres a hole up into the pan with a big plug in the top of it, get the tranny warmed up pull the plug and squirt fluid up and into the pan till it runs out, dextron III will work ok, you will need some sort of pump with a short piece of tube to stick up into the tranny's *******, you gotta sorta squirt at a angle to get it in the pan or it will just fall back down out of the gaping *******
  1. False "Washer Fluid Low" warning
    By Jay 535i in forum 5 Series BMW
    Last Post: 12-19-2006, 04:23 PM
  2. Replies: 5
    Last Post: 12-26-2005, 06:22 AM
  3. Replies: 2
    Last Post: 09-06-2004, 10:13 PM
  4. Solutions for false "Washer fluid Low" error?
    By Mitch90535im in forum 5 Series BMW
    Last Post: 05-12-2004, 10:36 PM
