My car is reaching 150K and it's running pretty well. I'm planning a trip to Florida in August and plan on taking the 535. It's a 900mile drive. Is there anything i should check/replace before i go on this trip?
I'll be replacing these soon:
-V-Belts
-Coolant
-Rear Muffler
-Oil & Filter(Castrol GTX High Mileage) I had 10W40 last change
Things I've recently replaced:
-Ignition Coil (because my car died and i thought that failed)
-Crank Positioning Sensor (That's what had failed)
-New Tires
-Water Pump
-Fan Clutch
-Fan Blades
-Drive Shaft Center Support Bearing (I still get a whistle sound from the drive shaft)
-Brake Pads and Rotors (less than a year ago)
I'll probably want to change my Trans. Fluid too.
What could fail and keep my car stranded somewhere i don't wanna be and have to spend lots of money to fix?
Thanks.
