Results 1 to 8 of 8
Thread: Intermittant Fan Clutch
    Default Intermittant Fan Clutch
    This is an interesting problem. My fan clutch only operates intermittantly. It seems that most of the time it doesn't engage when the air conditioning is turned on. Turning the air con off then waiting a bit seems to fix the problem. It also doesn't seem to engage at idle speeds. It only engages around 1300 RPM or so. I don't know if that's normal or not. When it does engage, it works perfectly. Is the clutch itself broken or is there something else at fault here?
    Reading, UK
    Quote Originally Posted by J.DeFeo
    When your aircon is switched on, an aux electric fan should be running in front of the radiator, this would explain why the visco fan doesnt kick in properly.
    Interesting that it only snatches over 1300 rpm though...
    Quote Originally Posted by Ferret
    I forgot to mention that my temp guage goes past the 12:00 mark if I'm just idling with the air con on. If I let it sit too long it will go way past it. So maybe the aux elecetric fan isn't funtioning?
    Feb 2007
    GreenHills East-Philippines
    Try checking your aux.electric fan is working...if its not check your fuse and relay but if all is fine but your aux.fan works but its slow or sometimes not functioning maybe you have a defective aux fan already
    HID 5000k low 3000k fogs
    dynaudio seps. mc intosh amp
    Race logic TractionControl
    Ok, the aux electric fan is definitely not running. The fuse was completely blown up. I replaced the fuse and still nothing. Going to check the relay next but if that doesn't do it I guess the fan is broken?
    Feb 2007
    probably. I just changed mine months back...fuse keeps on blowing and sometimes fan isn't working...turned out to be my fan was on its way out... bought one from the yard for cheap
    Quote Originally Posted by bmwrp8
    Both relays work, and the fan runs fine on the "high" setting. I figured this out by removing the fan switch and shorting the pins. The relay clicks but the fan does not run on the "low" setting. This confirms that the ballast resistor is blown, correct?
    Just to be double sure I want one of these?
    Feb 2007
    yep i guess
  1. Individual temperature control intermittant
    By borderchris in forum 5 Series BMW
    Last Post: 09-30-2007, 03:28 AM
  2. Intermittant TRANS PROGRAM code
    By semiretired in forum 5 Series BMW
    Last Post: 02-19-2007, 09:06 PM
  3. Trans position indicator intermittant
    By av8r in forum 5 Series BMW
    Last Post: 08-27-2006, 08:33 PM
  4. intermittant wiper and no cruise control???
    By bullyd in forum 5 Series BMW
    Last Post: 05-29-2006, 02:18 AM
