Results 1 to 4 of 4
Thread: differences in steering columns
    Mar 2007
    Default differences in steering columns
    I bought a steering column yesterday from a local breaker. It is tilt. Mine is not. I was told, no worries, it'll fit.
    I start taking my column out of the car, when I noticed there is a (what I think) is a neutral saftey switch cable that seems to come out of the dash somewhere, and screw in where the ignition lock is. I saw the guy unhook it at the yard when he pulled it out. without that hooked up, it will not let the key turn back all the way and release.
    I could NOT find this cable in my car. I looked everywhere. Also, the airbag had a different plug. It had the same plug on the wheel end, but a different plug on the firewall end.
    I am taking the column back, and they are going to replace it. If I run into the wire difference again, can I just use my old wire from my old column, or should I also switch the airbag??
    Honolulu
    Default Get the wheel
    that went with it.
    If you're retro fitting this to an older model the steering wheels are differant.
    check the knee bolster from the tilt car, it may be different.
    Grab as much of the wiring and trim as possible
    Mar 2007
    I don't want to retro fit. I am trying to find a direct replacement.
    I have located one. I went to pick it up, and the idiots cut all the plugs going to the column. So now I have to wait on them to order another one from a different location. The good news is they are going to ship it directly to my house.
    Thanks for the input, though
    Roswell New Mexico
    whats wrong with the original streering column?
  1. M5 differences.
    By Barney Paull-Edwards in forum 5 Series BMW
    Last Post: 09-09-2007, 04:03 PM
  2. Steering box differences
    By Jan in forum 5 Series BMW
    Last Post: 09-09-2007, 01:25 PM
  3. What Differences from e34 to e39 ?
    By BMWDriver in forum 5 Series BMW
    Last Post: 08-02-2007, 10:45 PM
  4. Why can I keep it in columns in testing area?
    By DaCan23 in forum 5 Series BMW
    Last Post: 01-12-2006, 01:08 PM
  5. LKM Differences?
    By GS535i in forum 5 Series BMW
    Last Post: 04-01-2005, 03:05 PM
