Just a thought but sitting for ten-months does not a valid comparison make. Most rotor "warp" is not from warping but from surface problems like rust or pad goo from sitting. Couldn't really tell if you had a brake shake problem before the car sat. MM's are made in so many different countries under so many different labels you can't say for sure that the same pad material is in play on both cars even if the box is labeled the same. Also, I've had very poor luck with Ate rotors on my E28, even Brembo rotors sucked using E34 rotors and E28 M5 calipers. I'd try and stick with Balos if you can, or whatever brand come from your local BMW dealer. They always seem to work better.
