Results 1 to 7 of 7
Thread: Timing Chain Cover gasket leaks
    May 2006
    NH
    Default Timing Chain Cover gasket leaks
    Saw it today at one of the local BMW shops while up on the lift. A goose neck bulb from up underneath straight up revealed one clear shiny metal spot with fresh oil where everything else around it was black gunk. They explained its a fairly involved job taking the alternator and water pump off that the water pump removal will disturb lines going to the rear of the head necessitating the removal of the intake valve which of course means new gaskets there but also the oil pan. I guess about $2,000 .00 and he could neither confirm nor deny it so i await a proper quote. Whats a fair price to replace the gaskets on the Timing Chain cover on the 540 M60?
    1995 540i Manual build 1/95
    Norcross, GA
    Is it upper timing cover or lower? I heard it is the upper timing cover that often leaks. I guess for upper it is not necessary to remove water pump.
    Arun
    530i / Nikasil M60 3 Ltr Motor / ZF5HP18 (A5S 310Z) Tranny / Prod: March 95 / Fully stock / 95K miles
    May 2006
    NH
    Lower on the drivers side.... he was telling me the oil pan,intake manifold, water pump and alternator as well i assume as the radiator need to come out. Another shop has since told me its about a 10hr job and he's $85/hr so that's good.
    They think its #11 on the drivers side.
    http://www.realoem.com/bmw/showparts...30&hg=11&fg=10
    Default Depending on whose
    flat rate time guide you go by, its from about 12.5 hours to 19.5 hours for the lower timing cover seals and gaskets to be replaced. Bmw's ksd comes out to slightly under 13 hours. Mitchell and alldata range up to 19.5 in their guides. Unless it was fairly large leak I wouldn't dream of paying that. I don't believe that its a pressure leak at that location so i'd probably just remove enough stuff to get at the outside of the timing cover and clean it good with brake spray cleaner, get it completely clean then run a bead of RTV down the outside cover seam to reseal it and see if that stops it. I'd wait at least a day for the rtv to cure before starting the engine to check for leaks.
    Quote Originally Posted by Jehu
    May 2006
    NH
    I drive it pretty much daily, the approximate time between the Low Oil level warnings after adding about a half-2/3 qt was about three weeks. It leaves an oil stain about the size of the palm of your hand after stopping when up to operating temp then stops i assume after the oil drains down past that point. I'll mention your RTV suggestion to the shop and see . The section of metal which was clean and shiny was about one inch in length weather that means the entire corresponding gasket is gone or the action of the leaking washes that far from a much smaller opening i wouldn't venture to guess but i know where to look and i'll show the Shop I have in mind .Thanks.
    Sep 2006
    San Jose, CA
    Sorry to bring up an old tread. I seem to have the same problem on the driver side time chain cover. It has been a very slow leak, but now it's getting worst. Is this the right part?
    http://www.autohausaz.com/search/pro...er=11141436978
    Jehu, did you end up fixing this? I will get a quote from my mechanic in a couple of days.
    94' AlpineWhite 530i, 5 spd Auto, 112K miles, Mfg in 4/93
    Just had gasket on left bank on my 1995 e34 530i touring changed at independant garage. $250 parts and $700 labour. Right bank easier.
  1. HALP! M30 upper timing chain cover in SE Mich?
    By paanta in forum 5 Series BMW
    Last Post: 05-23-2009, 03:47 PM
  2. Timing chain cover question
    Last Post: 08-24-2007, 10:37 PM
  3. 535i timing chain cover
    Last Post: 08-28-2006, 12:19 PM
  4. timing chain cover gasket
    By marckula in forum 5 Series BMW
    Last Post: 08-18-2006, 07:56 AM
  5. timing chain cover
    By jjdickm in forum 5 Series BMW
    Last Post: 04-13-2006, 03:23 PM
