Originally Posted by
JoeCinVA
FYI:
1) After some research: There is a 10 pin capacity female connector in the E46 auto-dimming/ LED mirror. See pic. However, there are only 9 pins in the connector of which only 5 are needed to use the auto-dimming/ LED function. (No idea what the other 4 are used for).
Auto Dimming Function
Pin 1- Reverse Lead
Pin 3- Switched 12V
Pin 10- Ground
LED Function
Pin 8- LED Pos
Pin 9- LED Neg
2) If someone cut the E46 wiring harness and provided you the male side of the 10 pin connector, the wire colors associated with the pins are as follows:
Pin 1- Blue/ Yellow
Pin 3- Green/ White
Pin 10- Brown/ Black
Pin 8- Red/ Black
Pin 9- Grey/ Black/ Yellow
3) If you didn't get a hacked up E46 wiring harness: here's what you can buy:
61-13-1-383-570, Qty-1, Male 10 Pin Connector
61-13-1-383-840, Qty-1, Connector Cover
p/n unknown, Qty-1, Connector Cover Lock
61-13-0-005-197, Qty-5, Female Bushing Contact
5 assorted colors of 18 gauge wire
