cut the rubber hoses and replace them and all 4 clamps at the same time?
I found myself in a sticky situation for the second time when attempting to begin the fuel filter change on saturday (first time i found a leak in a fuel pipe elsewhere and had to sort that). Anyway I get the wheel off etc and loosen the big nut holding on the fuel filter itself - then go to undo the two hoseclamps on the hoses leading in and out of the filter. One is so rusty the head crumbled and the other has a dodgy head which aint gonna turn either.
Options...
1. Cut the hoses just before the clips (1/2") as there is some slack anyway.
2. Saw through the hoseclamps with a little hacksaw (Cause a spark? - BOOM!)
3. Try and pull the hoses off the filter with brute force (normally option 1).
4. [empty space - open to ideas]
I dont think Wd40 is gonna do it even though it does have seemingly magical powers.
I have searched the archives prior to this thread - still need advice as i hate working on anything fuel related, i can set things ablaze by just looking at them.
I agree with the above post. Use a large snip or wire cutter to remove the hose. A new sharp razor knife will work also. Make sure to cut it evenly.
Greg Mannino
I didn't even think of that Jeff - i'll get under tomorrow and see how bad the clips are at the other ends!Originally Posted by 632 Regal
If they wont come off i'll have to chop the pipe and just have it with a little less slack on each pipe and replace the hoseclamp things.
Just out of interest how much fuel will come out of the filter and pipes if i dont de-pressurise the system (pull out the fuse and start it)? I have read threads that advise not doing the fuse pulling thing as its bad for the car?
Thanks!!!
