Results 1 to 3 of 3
Thread: door hinge makes noise
    arkansas
    Default door hinge makes noise
    I have a 1994 525i and the door hinge makes a big banging noise when you open the door. It is the driver side door. I did take the rubber boot and the metal from the door bends when you open the door from halfway to all the way open. Is there a part that needs to be replaced in side the door? Has anyone had this problem and how did you fix it. thanks
    Try to grease it
    http://www.autohausaz.com/secure/Par...1218155698.jpg
    I used motor bike chain grease which is very sticky and does not flow/drop.
    In case no improvment, replace it asap.
    http://www.autohausaz.com/search/pro...r%20Check/Stop
    Otherwise you might have that problem
    http://www.koalamotorsport.com/parts-home.asp
    arkansas
    thanks for the info... thanks again...
  1. Fuel Door Hinge
    Last Post: 05-03-2009, 09:34 PM
  2. Fuel Door Hinge Replacement
    By Super90 in forum 5 Series BMW
    Last Post: 08-14-2008, 09:44 AM
  3. Oh boy: Door brake/hinge failure
    By Denton in forum 5 Series BMW
    Last Post: 11-23-2007, 01:04 PM
  4. Procedure for gas filler door hinge
    By willobmw in forum 5 Series BMW
    Last Post: 04-03-2004, 01:06 PM
