Results 1 to 7 of 7
Thread: Radiator Cleaner?
    Sep 2006
    San Diego, CA
    Default Radiator Cleaner?
    I'm replacing the radiator in my '94 530i this evening. I'm planning on flushing out the green stuff and replacing it with Zerex G05 on a 50/50 mix with distilled water. I'm considering putting a can of cleaner through the system as well, but don't know if this is a good idea or not.
    Whaddya think?
    www.universal5.com
    Orange Tool Forum
    San Diego, CA
    1994 e34 530i Eibachs/KYB
    0 miles on new windshield
    Albuquerque, NM
    Some of the commercial products scare me in an engine with an aluminum head and waterpump and a headgasket that is problematic to begin with. I've had good success using citric acid, available in powdered form at a pharmacy or candy shop. It does a great job dissolving calcium deposits without attacking hoses or weak gaskets. I empty the system including the block drain, and use about a cup with tap water and run it for about 15 minutes with the heater full blast & then let it cool and do repeated fill-run-cool-drain routines with water until it comes out clear.
    gale
    Lexington, Kentucky
    Prestone makes two types of flush/cleaner. One you run for 5 minutes and flush/drain. The other you partially drain raid, add water and cleaner and leave in for x miles or about a week. Then drain/flush. It also has some sort of citric additive as a cleaner.
    I used the second type, flushed out rad and block with distilled water and filled with g05/distilled water. No problems. Works/acts exactly as it di before with BMW blue only yellow colored.
    the best radiator cleaner costs $275-325, cleans that old radiator right outta the core support and off the car
    Sep 2006
    San Diego, CA
    It actually cost about $235 for the radiator itself. Got a Nissen. I figured I'd run the cleaner through the block, but I think I'll just flush it now. Looks like I finally found a store that carries the Zerex G05 so I'm off to the FLAPS now.
    www.universal5.com
    Orange Tool Forum
    San Diego, CA
    Benneton (United Colors of)
    that cleaner will probably be at a much stronger concentration than it was designed to be present at if you use it to flush out your radiator only.
    Default Napa
    I've used their stuff which comes in powder form in a can. After one can, lots of crud and rust came out. After the 2nd can, a little more stuff got flushed out. Then I topped it off with a flush of distilled H2O and I was good to go.
  1. Manual Radiator Vs: Auto Radiator?
    By sneekens in forum 5 Series BMW
    Last Post: 04-14-2008, 07:22 PM
  2. Hub Cleaner ?
    By Roderick in forum 5 Series BMW
    Last Post: 06-09-2007, 02:38 PM
  3. CRC MAF Cleaner, Anyone used it?
    By araine901 in forum 5 Series BMW
    Last Post: 02-13-2007, 09:01 AM
  4. Replies: 6
    Last Post: 08-27-2005, 09:48 PM
