On the smiley housings, you can assemble the light canister in two different ways. You can set the housing to the L/G or the R/D setting. The setting changes the angle of the cutoff plate in ellipsoid...
ANYONE KNOW THE CORRECT SETTING?
I think this relates to the if the light applies to a left or right side drive car.
Is the setting the same on both sides or ??
Car's apart. No luck in TIS.
Jeff
