Results 1 to 8 of 8
Thread: gas pedal removal
    So.. how did you manage to change the carpet from tan to black?
    Jan 2007
    Dayton Ohio
    Default removing carpet
    I pulled all of the seats. Pulled the center console. Then I used a steak knife and cut around the center hump and removed the old carpet. Trick is to keep it close to the area around the heater core and such. Lay in the new carpet. In my case it was a great used carpet. Once you reinstall the center console you will not be able to tell the difference.
    Jan 2008
    Phoenix, AZ. USA
    I just did the same thing, swapped out my carpet and what a difference it makes. Just be careful, if you are cutting the carpet around the heating and cooling components, not to accidently cut into any wires. And thanks for sending me those pictures detailing how to remove the pedal, what a life saver...
    Jan 2007
    Dayton Ohio
    Default Most welcome
    Glad it helped
    Ken
  1. wtb manual pedal box
    Last Post: 05-24-2007, 05:37 PM
  2. Cluster removal without steering wheel removal...
    Last Post: 02-18-2006, 04:08 PM
  3. dead pedal
    By darron525 in forum 5 Series BMW
    Last Post: 01-19-2006, 08:35 AM
  4. accelerator pedal
    By dusntwrk in forum 5 Series BMW
    Last Post: 04-27-2005, 10:28 AM
  5. little clutch pedal
    By guy in forum 5 Series BMW
    Last Post: 05-03-2004, 08:21 PM
