Hi everyone. I have done this job before a couple times and I remember there is always a little trick to install the rear brake pads. I have pressed in the caliper piston all the way with a large C clamp. I have installed the inner pad, the one with the 3 clips and that is seated all the and makes contact with the caliper piston. The problem I am having is figuring out how to install the outer pad. I can't seem to get enough clearance to slide it in. I have done this before but I can't remember how I did it. Any ideas would be greatly appreciated.
Al Gray (Age 60 but still young at heart)
