Thread: front end shake when braking ....
    Dec 2005
    VT
    Default front end shake when braking ....
    Hi ... Last year I had the same problem: when I step on the brakes the front end shimmies violently, really bad. They replaced the outer tie rod ends, brake rotors and pads, etc.
    Now its doing the same thing again. When I drive straight (not when I turn) and brake the front end shakes like . There is no play in the wheels and it runs straight and smooth unless I brake.
    What could be the most likely cause(s).
    I got about 98K on it.
    Thanks for any help.
    May 2006
    I orginally had the same problem only during breaking, that was on my 15" wheels. I went to 18"s and then it was happening at 60mph regardless of whether I was breaking or not. Upper and lower control arm replacement fixed it all up.
    1995 540i - Cosmosschwarz Cosmos Black Metallic Black
    Style 71 18's
    EAT Performance Chip
    Dinan Transmission Chip
    Aug 2004
    Regional NSW, Australia
    What are your thrust arm bushings like ?
    "I'm not the village idiot.
    any play will cause this shimmy with thrust arm bushings being #1 on the list. Check the nut behind the wheel for play first, it will seem tight but if you wiggle the steering wheel with your hand while feeling for play behind the nut.
    1. Thrust arm first...
    2. Lower control arm second...
    Dec 2005
    VT
    thanks guys .... I'll check it out and report back.
  1. Replies: 4
    Last Post: 09-02-2008, 03:58 PM
  2. light braking/wheel shake??
    Last Post: 04-14-2007, 10:46 AM
  3. front end grind noise on hard braking
    By pba in forum 5 Series BMW
    Last Post: 09-04-2006, 05:25 AM
  4. front end shake
    By Eric K in forum 5 Series BMW
    Last Post: 07-17-2005, 09:33 AM
  5. front weels vibrate when braking
    By grave77 in forum 5 Series BMW
    Last Post: 10-13-2004, 12:32 PM
