Results 1 to 10 of 10
Thread: So I pulled off the AFM....
    La Mirada, CA
    Default So I pulled off the AFM....
    Ew...tips, comment, suggestion?
    CRC AFM cleaner... available anywhere... Pep Boys, Walmart... etc.
    Bay Area, CA
    get an MAF...
    I recently installed my Miller MAF and couldn't be any happier.
    La Mirada, CA
    well i used simple green an drags to clean out fingerlength inside the afm...should i see any mpg increase from the little bit of gunk??
    also im waiting on mark's maf...
    i wirebrushed the entire head and it looks amazing
    hwo do i take off that wire bundle at the bottom of the 1st pic...spark plug wires or ignition wires whatever???
    La Mirada, CA
    after:
    The wire harness on the bottom is attached with two nuts (IIRC). Look around the bottom of the plastic sheath and you should see them.
    TC535i Guest
    Quote Originally Posted by Rus
    See the "BMW" on the valve cover? Look straight down from the center of the "M"... see that little nut there? That one does it, I think... there should be another too.
    TC535i Guest
    I think I see the other nut just to the left of the hose clamp screw for the intake hose there.
    La Mirada, CA
    Yea..tho I dident feel like searching for the right size socket to drop a nut down the engine comparment haha one of these day once i get my real estate license and close my first sale ima rebuild the engine
    La Mirada, CA
    also i anna know where did all that "oil" crap come from after i pulled the afm off? (first post)
  1. Replies: 2
    Last Post: 04-07-2008, 07:11 PM
  2. Pulled out the ICV
    Last Post: 06-05-2006, 10:31 AM
  3. So I pulled the trigger...
    Last Post: 05-11-2006, 06:24 AM
  4. OT.....so i pulled the trigger again. No A-fools..
    By paul p (chi-town) in forum 5 Series BMW
    Last Post: 04-08-2006, 04:49 AM
