I thought i read there are some Pan bolts behind the bell housing so it needs to come away but don't quote me. here's what the Bently manual says;
To remove and install oil pan (M50 engine)
1. Drain the engine oil as described in 020 Maintenance
Program.
2. Disconnect the oil level sensor harness connector.
3. Remove the radiator cooling fan and the fan shroud.
See 170 Radiator and Cooling System.
NOTE
The
radiator cooling Ian nut
(32 mm wrench) has tett
neno threads.
4. Release the drive belt tension and remove the engine
drive belt. See Fig. 5.
8 11143
Fig . 5. To remove pofv-ribbed dnve belt. pry cover from trorn of tensioner.
Then uSing
Brnrn hex key. turn tonsioner clockwise
(arrow) to release tension and slip belt on pulleys.
5. Without disconnecting any fluid lines. remove the power
steering pump and its bracket from the engine block.
See Fig. 6. Support the pump from the body using stiff
wire.
6. Remove the oil dipstick guide tube mounting bolt and
remove the tube. See Fig. 7.
NOTE
The
guide tube is sealed in the bloc!< using an D·ring.
Check that the D-ring comes out with the tube. Use
a
new D-ring when installing the tube.
Fig. 6. Power steennq pump mountinq bolts (arrows).
Fig. 7. Oil dipstick guide tube being removed. Use a new O-ring
(arrow) during installation,
7. On cars with automatic transmission. remove the
brackets that hold the ATF cooler lines to the oil pan
and cylinder block.
8. Remove the oil pan mounting bolts and lower the oil
pan to the subframe crossmember.
OIL PAN
119-6
LUBRICATION SYSTEM
WARNING
II
the oil pan does not separate easity Irom the engine
cylinder btoc!<.
a lew taps with a rubber mallet
should break it Iree. Do not pry the oit pan loose.
5. Remove engine and transmission splash pans from beneath
car.
6. Disconnect harness connector at oil level sensor.
9.
Unbolt the oil pump pickup tube from the oil pump and
then remove the oil pan from the rear.
7. Remove oil pan lower section. See Fig. 8.
0011516
U
.. '-.U- - - - - - - -l
Tighten the oil pan bolts evenly in stages. Reconnect the oil
level sensor harness connector. Use a new O-ring when installing
the dipstick guide tube. Fill the engine with oil as described
in
020 Maintenance Program. After adding the
engine oil, start and run the engine. Raise the engine speed to
2,500 rpm until the oil pressure warning lamp goes out (about
5 seconds).
Installation is the reverse of removal.When installing the oil
pan, apply a bead of non-hardening sealing compound (Three
Bond®1207B or equivalent) to the front and rear end cover
seam areas on the block. Position the oil pump pickup tube
and the oil pan onto the block and install the pickup tube using
a new gasket. Be sure the tab on the gasket faces down to wards
the intake of the pickup tube.
Tightening Torque
• Oil pan to engine block 10 Nm (89 in-Ib)
Fig.
8. Oil pan lower section mountmq bolts (arrows) on MOO engine.
Oil level sensor shown at A.
