Results 1 to 10 of 11
Thread: my e34 wont start!
    Apr 2007
    Default my e34 wont start!
    i turn the key, and every light will come on, but will not even try to spark. just dead. the battery is charged so that isnt the problem. fuses look ok. we were going to replace the drm relay but i cant find out which one it is. there is no information on what each of the relays does.
    other than that, any help watsoever would be much appreciated!
    1995 m50 520i executive
    Honolulu
    Default The main relay?
    Quote Originally Posted by adashio
    it's in the E box between the computers, it's white.
    Check the CPS Ohms, it could also be a culprit
    Apr 2007
    Quote Originally Posted by Blitzkrieg Bob
    does the car think its being stolen? would that make it not able to start? if how do i "reset" the car?
    does the engine turn over? And what do you mean by NO SPARK?
    Apr 2007
    Default engine does not turn over
    yeah, no spark means engine doesnt even try to turn over.
    From your initial post, I'm assuming the starter isn't even engaging (engine not turning over). Do you hear a clicking noise? I don't know anything about alarms, but someone hear might lend a hand. I've had a similar thing happen and when I boosted it with jumper cables, it worked, even though I believed my battery was healthy. Might be worth a try.
    Here is a pic of the relays in the "e-box'" located on the passenger side near the firewall.
    Dave
    Top green relay is the DME. I'd try jumper cables first.
    May 2006
    NH
    While you've got that pic up I thought i;d ask if i read somewhere here a trick to rid the Fuel lines of fuel to change the Fuel filters you pull that relay and start the car to use up the fuel in the lines then you will have less pouring out when you pull the lines or was it the pump fuse?
    1995 540i Manual build 1/95
    Apr 2007
    Default jump starting a no go
    jump starting doesnt work. tried both the actual battery an under the hood. this problem happened intermittenly yesterday, turn key, wouldnt start, turn key again and started
    but today it wont start at all!
    any ideas?
    thanks so far!
    Great Britain
    Does this problem only happen when the engine is warm? If so then do a search for recent posts for me on this problem and one way of curing it.
    Otherwise, could be the battery, starter relay, ignition switch or starter motor.
  1. 92 525 wont start
    By kzpuck in forum 5 Series BMW
    Last Post: 04-25-2008, 05:22 AM
  2. Help - E34 wont start
    By kwbimmer in forum 5 Series BMW
    Last Post: 03-20-2007, 04:32 PM
  3. Help!!!! Car wont start!!!
    By GoldenOne in forum 5 Series BMW
    Last Post: 09-24-2006, 09:08 AM
  4. car wont start...
    By pong in forum 5 Series BMW
    Last Post: 09-16-2006, 03:59 AM
  5. Car wont start
    By 1991 525i Novs in forum 5 Series BMW
    Last Post: 06-16-2006, 04:16 PM
