Results 1 to 3 of 3
Thread: Torque specs needs for the 3 bolts holding the plate under the subframe bushing
    Aug 2004
    VA
    Default Torque specs needs for the 3 bolts holding the plate under the subframe bushing
    HELP!! - I am installing Bruno's Delrin bushings on my '95 525iT and snapped one of the 13MM headed bolts upon re-installation. Luckily, I was able to back out the snapped bolt fairly easily.
    There are two 13MM headed bolts and ome 22MM nut that keep the plate under the subframe bushing. Can anyone please tell me what the torque specs are for these bolts? I did not see a torque spec for these bolts and nut in the Bentley manual.
    Feb 2007
    New Forest, ,UK,
    To snap the bolt, either you are a gorilla or the bolt was duff! Regardless of its useage the max torque of an eight mm bolt(13mm head) is about 31ft/lbs but I would suggest using 25 and loc-tite.You would be shocked at the max torque on smaller bolts unless they are hi-tensile(gr8 in colonies I think),even a .......ian can break a 6mm bolt with little effort.CLEAN the threads and the hole in the car.
    Aug 2004
    VA
    Quote Originally Posted by Barney Paull-Edwards
    Barney, I have a bad habit of snapping bolts at the worse times, either with hand tools or my impact wrench. In this instance, it was my old, reliable Ingersol-Rand 1/2" drive impact wrench that snapped that bolt, but I thought I was safe with it set on its softest setting. I should have known better, but without the torque spec, I was trying to install it quickly. BTW, that bolt appeared to be a Grade 5 bolt. I picked a couple of replacement bolts up today at a local junk yard off a junked BMW 5 series car and finished the job.
  1. E34 Subframe bushing
    By Scott C in forum 5 Series BMW
    Last Post: 10-11-2009, 08:00 PM
  2. Replies: 7
    Last Post: 01-05-2008, 10:39 PM
  3. What's the torque setting for the 10mm bolts holding...
    By darren540i6 in forum 5 Series BMW
    Last Post: 07-05-2006, 11:14 PM
  4. A better E34 subframe bushing?
    By GS535i in forum 5 Series BMW
    Last Post: 01-30-2006, 07:27 AM
  5. can somebody pls look up subframe bushing part nos. ...
    Last Post: 11-03-2004, 02:13 PM
