nt
The steering on on my 91 525i seems to be pulling left and right. it becomes more pronounced at speeds above 55. It also seems to be caused by bumps and irregularities onthe road as it will track straight for a while then vere over small bumps. everything i checked seemed tight and didnt show any visible signs of wear. The steering box had been replaced with a used one a while back bc of too much steering play.... any advice would be helpful.
J. Stauffer
91 525i 257k
nt
Tires could be worn funky or loose steering componants which you said you checked. The other thing is alignment may be off a few degrees, replace whatever could be iffy and get an alignment.
Check your rear sub frame bushing. See my previous post.
http://www.bimmer.info/forum/showthread.php?p=14578
