Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: A/c light won't come back on after shutoff and restart.
    Albuquerque, NM
    The hi/lo refrigerant pressure switch is mounted on the receiver-dryer. On most models the dryer is mounted in the engine compartment, down low, behind the right headlights. You might have to remove the airbox and washer reservoir to get to it.
    gale
    Jul 2005
    Default So looks like I may have to open up the system?
    I was trying to avoid having to have the "a/c professionals" having to get involved. Will changing the pressure switch open up my refridgerant system?
    Quote Originally Posted by gale
    Sep 2005
    Dallas, TX
    You're probably low on refrigerant. I had the same issue, and in testing for leaks, we put in some UV dye. As soon as I had a bit of coolant in the system, the AC light would come on.
    We found the leaks at one of the schraeder valves and the seal to the compressor. I am currently awaiting a new compressor.
    Have your system checked for leaks.
    Forget about the switch. Yes, it will blow out with all youre refrigerant and causing you harm. Just hook up the gauge... you can buy a refrigerant can with the gauge and hose hooked up to it.
    Albuquerque, NM
    Quote Originally Posted by mossyoaks
    Yes, swapping the switch will expose the innards to atmosphere. I'd try El Guapo's suggestion 1st. If you can measure the pressure that's in it now and verify it's not totally empty of refrigerant, then you can probably safely add a can to it. Best to slap a set of gauges on it to make sure it's not overfilled. Any car in the US manufactured after Jan 1993 will have R134a which is cheap and available just about anywhere without a license. You should have a label under the hood stating it's R134a.
    If you find it's completely empty and has been at atmosphere for some time, then it's best to replace the receiver/dryer and pull a good vacuum on the system and fill it with X amount of pounds of refrigerant. Do a Google search & find out if you should add a token amount of Pag oil when putting in a new receiver/dryer. Do what Guapo suggested and put some dye in it as well.
    gale
  1. Still a mystery...a/c quits on restart when hot?
    By filmy540i/6 in forum 5 Series BMW
    Last Post: 06-05-2008, 01:24 PM
  2. Engine dir and won't restart
    By Jay 535i in forum 5 Series BMW
    Last Post: 02-19-2007, 09:51 AM
  3. Back up/reverse light...please help.
    By Triv in forum 5 Series BMW
    Last Post: 03-25-2005, 09:52 AM
  4. Back-up Light switch
    By Davy in forum 5 Series BMW
    Last Post: 01-31-2005, 05:32 AM
  5. Humming after shutoff
    By cappy in forum 5 Series BMW
    Last Post: 05-21-2004, 11:05 PM
