Results 1 to 7 of 7
Thread: R134 Low pressure tap?
    Sep 2006
    Newnan
    Default R134 Low pressure tap?
    First time charging the A/C, anyone have a pic of where to tap into the low pressure side, for a fill-up?
    1995 BMW 530ia/3.15lsd/M Parallels/Eibach/Bilstien/Magnaflow
    No pic. On the pass side inner fender toward the firewall you will see the two refrigerant lines, the larger one is the low pressure side.
    Ya... it is practically sticking up... easy access. High pressure are always much harder to access and way out of way to prevent people from hooking it up. In any case, low pressure fitting does not fit on the high pressure fitting.
    Sep 2006
    Newnan
    ok great, i noticed the two and didn't know if that was it or not, i may have to look but aren't they the same size?
    Edit:
    Just went out and took a look, there is indeed a larger pipe, the one closest to the firewall seems to be it...
    Thanks guys!
    Nope, both are in a foam jacket, the lines are different size and like tiger says the fitting are also different.
    Sep 2006
    Newnan
    i edited my post thanks!
    Feb 2007
    Minneapolis, MN
    It's up nice and high on the right. Can't miss it. Spent an hour trying to locate on one of the kids Ford Focus recently. Finally found it in the freaking wheel well buried under the fender liner! No wonder Ford is going **** up!
  1. can you use a r22/r12/r502 gauge set for r134?
    Last Post: 09-14-2007, 11:41 PM
  2. AC compressor R134 compatible or not ?
    By Claude in forum 5 Series BMW
    Last Post: 09-27-2006, 10:24 PM
  3. R12 to R134 conversion question
    By Mr. BILL in forum 5 Series BMW
    Last Post: 09-09-2004, 02:17 PM
  4. Anyone paid to have AC retrofitted for R134 freon?
    By Abnormal in forum 5 Series BMW
    Last Post: 04-19-2004, 09:53 AM
  5. can somebody tell me how to check for r134 or r12...
    Last Post: 02-20-2004, 11:38 PM
