Yes
I received door trim, clamps, and grommets for my rear doors. Question: In this image here,
Parts 5 and 6 - do they just pop into the holes? I don't have to remove the interior door panel? I am curious because I don't completely understand the function of the grommet, if this is the case....
Yes
I popped them in, and they seem secure - but what is the grommet for?
You're supposed to used them both... A bit of over engineering if you ask me... I didn't used the grommets either, no need to, it's plenty stong without them... I guess it is for a better fit or something...
Jeff
I prefer to be misunderstood rather than having to explain myself all the time...
well glad to hear i'm not alone![]()
Part 5 is only for use on the outer portion of the trim.. whereever there is a hole big enough to accommodate the grommet you place one...
you probably didn't need one on the trim you replaced
