Results 1 to 4 of 4
Thread: both rear windows not opening
    Illinois
    Default both rear windows not opening
    i just noticed that both of rear windows are not opening. I tried using the buttons up front as well the ones on the individual windows.
    Not sure what happened. They were working earlier last week.
    Any ideas?
    I checked the fusebox and it looked okay although I don't know exactly what to check for or what # the fuse might be).
    Any suggestions?
    Thanks.
    Child lock mode on?
    See the small rectangular button in the middle of the window switch block?
    See owners manual.
    Dec 2006
    Melbourne, Australia
    This happens to me sometimes. Press the button and listen out for a click or a motor trying to move the window down. If that's the case, you might need to take the door cards off and examine. Shortcut way of fixing the problem temporarily is to slam your rear doors shut, usually the jolt shifts something inside, allowing the motor to overcome the resistance it was up against beforehand.
    Victoria, Australia
    Yep, used to happen to me; if you can hear a click when you press the button down, hold the button down, and hit along the bottom of the door. This will get it going again!
    Something about the bushes being too tight; or so my mechanic says.
    Old car: 95 525i, OB/Silver, Eibachs, Style 66, Missed dearly!!
    VIN Decoder | Online ETK
    | E34 Bible
  1. No power in rear windows (Down only)?
    By BadAss95-530i in forum 5 Series BMW
    Last Post: 06-23-2010, 12:19 PM
  2. Opening rear doors if power fails
    By Paulandjen in forum 5 Series BMW
    Last Post: 12-28-2006, 04:13 PM
  3. Rear Windows Don't Work
    By ProZak in forum 5 Series BMW
    Last Post: 06-10-2006, 05:57 PM
  4. Rear Windows Have Come Loose
    By John D in forum 5 Series BMW
    Last Post: 08-02-2004, 10:15 PM
