Originally Posted by
whiskychaser
Your first pic is the chain tensioner. Like you, I cut mine in half to save removing the head. On my car this pivots on a dowel. I removed the dowel, poked the end of the new tensioner up through the head and tapped in a new dowel and fitted a new circlip at the end.
Your second pic looks like the pin that you push the chain guide on to. It was one of these pins that sheared and I found it in the sump. On my car these pins have threads. I fitted two new pins and a new guide. (I also fitted the other guide that bolts on top of the head and two new chains)
I'm not sure what your third pic is I can only guess this is what the chain tensioner pivots on in your car?
After 9/94 BMW replaced the aluminum chain guide (BMW call this chain tensioner, I am used to the SAAB convention calling it the chain guide. But tensioner it is.) with one plastic. My 525i was a 5/94 production. It came with an aluminum tensioner. I cut it in half to remove it like you did so I did not have to remove the head. The only way I can fit the chain tensioner back was to use the plastic one because I can snap it in place. It is not possible to reinstall the aluminum tensioner back with the head in place. Since I didn't know how to remove the old tensioner pivot pin to install the new one which works with the plastic tensioner, I had to make use of the old pin. The plastic tensioner has a shorter width then the aluminum tensioner at the pivot. (Fortunately the pin diameter is the same.) To make it work I need to make up the difference in width. So I cut a piece from the discarded aluminum tensioner pivot to slip onto the old tensioner pin and reused the snap ring. The new plastic tensioner doesn't require a snap ring if fitted with the new guide. It just snaps in. I had to reuse the metal snap ring with the new tensioner, old tensioner pin combination.
'01 540it, 6/01
'03 325i 5 speed, 9/02
'10 535ix. 9/09
'10 mini 6 speed
'15 mini countryman 6 speed
