Results 1 to 10 of 10
Thread: How do you improve radio reception
    Jan 2007
    Dayton Ohio
    Default How do you improve radio reception
    How do you improve radio reception? Reception in my 89 535i is really bad. I have noticed that there is no external antenna. Can anyone tell me where the antenna is?
    Maybe you amp is not working (sits behind C-pillar cover).
    The rear window antenna and heater: The upper 3 lines on the glass are the AM radio antenna, the middle 8 are FM and defroster, and the bottom 8 are defrost
    pic from Bill R
    http://www.bimmernut.com/~billr/images/antenna.jpg
    The amplifier and the rest is behind the C-pillars of the car. For the rear window heater on drivers side, but also some is on passenger side. Just remove the covers from the C-pillars.
    The control of the defroster is done by the IHKA control unit. Maybe that is also not working.
    So take a multimeter and the C-pillar covers, switch the defroster on and see if you get power there in and out.
    Jan 2007
    Dayton Ohio
    Checked amplifier in trunk, seems the coax was loose. Also found the antenna module in the c-piller (rear driverside) the coax was loose there also. Tighten them up and seem to have improved receiption. Now I need to check for power at the amplifier. Is there a schematic or can you tell me what color wires are power?
    Nov 2006
    Maryland
    Does anyone have directions and pics how to do this? i have crappy reception too but it's intermittent when driving around.
    red wire and brown is pos and neg... Blue is the trigger to turn it on.
    Dec 2005
    Brisbane Australia
    Quote Originally Posted by Tiger
    cut the blue wire, no wait the red one.... its a booby trap. agh I'll do it with my eyes closed. 5....4....3....2....1...
    T·O·R·O·N·T·O
    Holy crud. Is that why the top three never defrost?! I always thought it was broken...
    pic from Bill R
    Sep 2005
    wilmington, nc
    We always have good luck with tin foil here in NC :>
    89 525, 86 jetta diesel, 07 wrx with mods, 06 commander
    1 mean wife, 2 daughters, 1 bull mastiff. At least the jetta
    is cheap to keep up.
    Sydney - Elizabeth Bay
    Certain window tints can effect reception. When I had all my glass tinted, I was told that metal based films can harm radio reception when fitted to the rear screens of cars like the e34's ( glass with ariels fitted within the glass). Supposedly, the cheap tints that turns purple are the ones that you fit to the rear screen to not effect reception.
    I had the more expensive film added to the rear screen, and experienced only a slight loss in reception.
    Stacy Au
    535i 5 speed '88
    Track pack = camber plates/king springs/m5 Nurb' sways/17"bbs 3pcRS e34 spec/chip.
  1. Stock radio reception is failing?
    Last Post: 09-28-2008, 03:30 PM
  2. improving radio reception
    By chamilun in forum 5 Series BMW
    Last Post: 10-17-2004, 12:56 AM
  3. '94 540i antena/radio reception
    By Matias in forum 5 Series BMW
    Last Post: 08-03-2004, 10:29 PM
  4. Stock amp important for radio reception?
    By Kennan in forum 5 Series BMW
    Last Post: 05-02-2004, 07:15 PM
  5. Radio Reception
    By Svennn in forum 5 Series BMW
    Last Post: 02-13-2004, 02:56 PM
