Results 1 to 10 of 36
Thread: New alternator, still not enough voltage
    Aug 2006
    Boulder, CO, USA
    Yes had to swap old pulley on there. Here's what i don't get though, i have tried 2 supposedly good v-regulators and this new alternator all with the same results. Voltage just drops when loaded. I did try another battery, i got 14v right after starting, but in a few minutes the voltages tanked. Are there any relays that would isolate the load of accessories from the alternator? I guess i don't see how it could put out all the amperage needed but still have such low voltage.
    The voltage regulator is bad, buy a new one
    Aug 2006
    Boulder, CO, USA
    Ross, i didn't make this clear but i tried that with the original alternator. So i have one voltage regulator that has run all of 20 mins and another that was on the rebuilt alternator. Neither v-reg in either alternator makes any appreciable power nor responds to load. Am i dealing with all bad parts here? Possible, but i find it hard to believe all the new parts i received are bad. Am i looking at a bad ground or something goofy like that?
    If it tested only 13 v on the bench I can only conclude a bad regulator.
    What happens if you disable the new lights you installed??
  1. M60 alternator/voltage regulator replacement
    Last Post: 05-24-2009, 02:54 PM
  2. Voltage regulator or Alternator?
    By Zackb911 in forum 5 Series BMW
    Last Post: 10-27-2006, 10:22 PM
  3. Alternator voltage and brushes question
    By pingu in forum 5 Series BMW
    Last Post: 05-03-2006, 06:22 AM
  4. Voltage
    By Whit in forum 7 Series BMW
    Last Post: 05-12-2005, 03:45 AM
  5. new brushes in old alternator voltage regulator
    Last Post: 05-11-2004, 12:12 AM
