.3 ohms is high. Should be very close to zero.Originally Posted by colo525i
Measure from - terminal of battery to alternator housing. Also measure from the + terminal of alternator to + terminal of battery. High resistance between either point won't allow your battery to charge.
E = I x R
E Voltage drop
I current in amps
R resistance in ohms
E=40 amps x .3ohms
E=12 volts drop
With this load there is no charging taking place
E=4amps x .3ohms
E=1.2 volts
assuming 14.4volts output from the alt that leaves 13.2 to charge the battery. Not adequate but at least the car will run.
When I measure mine it's practically zero on an analog meter, unfortunately my digital meter was stolen.
http://epg.modot.org/index.php?title...cal_Components
