Take upper hose off and see if you still have the ridge on the radiator that is supposed to prevent this from happening. I suspec the ridge is gone and your hose simply slides off under pressure.
I don't have the original cap.
The hose pops off because of the pressure building up in the upper hose.
I'm completely bamboozled at this point....
the radiator is fine... everything is in great shape.
nothing will keep the hose on because the pressure is great...
I dissagree, if this is the case then all kinds of hoses would be popping off everywhere not just at 1 location.
Have you tried using a hose clamp on the thing?
Originally Posted by Evan
I still think the nub is broken off and that all he has is smooth shaft.
I'm with Tiger and Regal on this one. Can you post a pic of the neck where the hose attaches to the radiator? And a pic of your hose clamp?
There are test kits available to detect exhaust gas in the coolant. Put a drop of something in a sample of coolant and see if it changes color sort of test.
If your pressure isn't accompanied by high temp then I'd start looking at a headgasket.
Is there a way to check the system pressure via a screw on cap with a guage? Just thinking out loud.
Dave
*RIP Oskar the DOG*
Yep, rad. pressure gauge
Sounds like the next thing I'd try.Originally Posted by Ross
*RIP Oskar the DOG*
