Results 1 to 8 of 8
Thread: M60 air leak/rough running
    Dec 2006
    UK
    Default M60 air leak/rough running
    Having a quick look just now at my car, I could feel an air leak on the PCV plate. The hose on the right of this picture has an air leak, and if you place you finger near the base of the hose where it enters the PCV, you can actually feel it being sucked in ( when a few mm above the leak, that is ) to plug the leak. The pipe seems to go onto the end of the fuel rail, so would this be a likely cause of the rough running,or does anyone know what this pipe is doing ?
    Cheers
    Austin, TX
    Quote Originally Posted by Sidney Rough-Diamond
    Cheers
    I just replaced this on my E39 540. It cured my rough idle and low rpm stutters. You might also check the hoses that connect to it, mine were all rotted.
    that hose regulates fuel pressure. any air leak will cause a bad idle.
    Tampa Bay, Florida, USA
    It goes to the fuel pressure valve/regulator.
    Ramon
    1994 540iA Nikasil EAT Chip
    Tampa Bay, Florida USA
    Dec 2006
    UK
    Quote Originally Posted by bimmerd00d
    Cheers. Would I have to remove the PCV to attach the new hose at the PCV end ? I'm guessing from the picture it is a simple push fit at both ends.
    Sep 2006
    San Jose, CA
    No need to remove anything to change that hose. I did it a week after I put the new intake gasket in - I forgot to order this little hose with the gasket.
    94' AlpineWhite 530i, 5 spd Auto, 112K miles, Mfg in 4/93
    Dec 2006
    UK
    I was going to the dealer tomorrow to order the E39 M62 engine cover clips as a mod for my broken posts, looks like I have another reason to go now. Thanks all for taking time to reply.
    Maryland
    what size is that hose? i'd like to pick up a foot or two at the auto shop
  1. running rough
    By edward in forum 5 Series BMW
    Last Post: 05-16-2009, 10:30 PM
  2. m30 running rough won't run idle fix
    By clarkstreet in forum 7 Series BMW
    Last Post: 02-28-2009, 09:08 AM
  3. rough running
    By jippijak in forum 5 Series BMW
    Last Post: 02-26-2006, 04:46 PM
  4. 540i/a running rough!!! please help!!!
    Last Post: 02-21-2004, 03:37 PM
  5. Please Help!!! 540i/a running rough
    Last Post: 02-19-2004, 04:12 PM
